12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Callout not displaying
I am using callouts to show smaller sections of a large site and for some reason, when I go to the callout sheet, it is blank. I have used this same trick for another site and it worked beautifully. I've compared the two and everything seems to be the same. I'm using 2011. Any ideas?
You say site - is there a linked file here? Check your VG - Is their an Imported CAD DWG? You haven't really given us enough information.
I have imported a site plan from Autocad. I was able to get it to display by doing a copy/paste into the callout sheet, but it seems like this is a workaround.
If I remember correctly you can bring in a CAD file into the view or into the file. If you just braught it into the view then it would not show anywhere else including a callout made from the plan.
Ah. Maybe that is what my issue is. Thanks!
Callout tags |
Thu, May 1, 2008 at 11:39:20 PM
12
callout only head |
Tue, Mar 26, 2013 at 7:09:20 AM
CALLOUT ISSUES |
Thu, Oct 9, 2008 at 3:34:15 PM
Rotate Callout Head? |
Thu, Aug 1, 2019 at 10:08:02 AM
Detail callout vs. Floor plan callout |
Mon, Nov 2, 2009 at 11:03:39 AM
