11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Edit group
in r2011 i notice there are times when I "edit/group" and there is no way to exit or save out of the edit group command. I end up ctrl-z backing up and cant save the edit session. I've looked in all the pull downs too. Do you know how to save out of it or why this happens? it happened in a group that was arrayed.
Go to View - User Interface - Check Recent Files - Click Modify - User Interface - UnCheck Recent Files and it will come back.
Perfect! how on earth did you figure that out?
4 Posts No Rating |
Using Revit Structure 2011 on Win 7. Same Problem of group window not showing. This Recent Files Check Box worked for me. Thank you for this! Top work!
29 Posts No Rating |
I'm having the same issue. I just want to add two keyboard shortcuts i use to exit the group FG: finish group (save changes) CG: cancel group
0 Posts No Rating |
Had this issue in RAC 2014. The recent files trick doesn't work. I managed to get out using the undo command several times.
Somethimes the hang-up is that there is a notification screen (a warning) that gets shuffled to BEHIND the windows/Revit screen and you need to <alt tab> to see that and clear or react to it.
In some installs, there is a file that is messed up in earlier installs. That may be your issue. But from one of the similar threads below, there was also this answer: "...
a shortcut
FG= finish group"
edit group panel missing |
Tue, Jan 17, 2012 at 2:54:43 AM
12
How to edit family parameres inside a group? |
Thu, Aug 25, 2011 at 12:21:16 PM
Changes to groups are allowed only in group edit mode - BUT I AM IN GROUP EDIT!! |
Fri, Nov 26, 2010 at 2:19:27 PM
can't make change to group with more than one instance [ 1 2 ] |
Sun, May 21, 2017 at 1:30:17 AM
16
group edit mode |
Mon, May 27, 2013 at 8:32:56 AM
