Forums >> Revit Structure >> Technical Support >> How to build and import objects
Sat, Nov 27, 2010 at 10:49:55 AM | How to build and import objects
MaxModeler
MaxModeler Avatar
2 Stars: 2 Votes
The library here isnt giving me what I need for certain objects. Im an expert modler in Max and was curious if I can build in max and import as .raf file?
In the day of my trouble I will call for you, for you will answer me.~ Psalm 86Blushing
Sat, Nov 27, 2010 at 10:57:03 AM | MaxModeler
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting MaxModeler from 2010-11-27 10:49:55
"The library here isnt giving me what I need for certain objects. Im an expert modler in Max and was curious if I can build in max and import as .raf file?"
do you mean .rfa file?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Nov 27, 2010 at 11:07:26 AM | How to build and import objects
MaxModeler
MaxModeler Avatar
2 Stars: 2 Votes
Yeah, still learnign the nomenclature. Noob here.
Sat, Nov 27, 2010 at 11:42:59 AM | How to build and import objects
4 Stars: 205 Votes
In Max you can export in DWG then import in Revit, like i told you before search in Forum what you need and you will find it, BTW, if you look at the bottom of this page you will see similar questions.
Sat, Nov 27, 2010 at 11:49:30 AM | How to build and import objects
MaxModeler
MaxModeler Avatar
2 Stars: 2 Votes
The questions at the bottom work some of the time and are vague on the topic and dont precisely offer up an answer sometimes. Keyword search is only as good as its database type. Believe me, Im not new to forums!....lol
Thanks for all your help. Ill try to keep the questions down.
Sat, Nov 27, 2010 at 12:35:20 PM | How to build and import objects
4 Stars: 205 Votes
" Ill try to keep the questions down." - it's not that, you can keep posting your questions of course but the answers are already here in forum, here you have a simple tutorial from "Maxlloyd" about your question: http://www.revitcity.com/tutorials/how_to_grow_your_family/
Sat, Nov 27, 2010 at 4:06:31 PM | How to build and import objects
MaxModeler
MaxModeler Avatar
2 Stars: 2 Votes
Thanks Typhoon.
Import 3D objects from VIZ to Revit
Wed, Jun 20, 2007 at 12:26:09 PM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
import dwg surfaces into Revit
Fri, Mar 6, 2015 at 1:56:09 PM
Best way to build stuff (not "buildings")? [ 1 2 ]
Sun, Nov 2, 2008 at 4:42:31 PM
24
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Page generation time: 0.2203
