Forums >> Revit Building >> Technical Support >> Problem loading custom family
Fri, Nov 26, 2010 at 2:11:22 PM | Problem loading custom family
suzyblue
I created a custom lamp using the generic family template.  I used the correct reference plane (ie: base of lamp is at table height) and saved it in my imperial library as I may reuse for other projects. Problem: When I try to load it into a project it won't show up. I go to the family menu in the project browser, click on the name of the lamp and drag it to the screen. My cursor becomes a circle with a line in it (like the "no ___ing" symbol). ALL Visibility graphics categories are on. Item shows in the components dropdown but won't appear on screen.   What am i missing?
 P.S. I am using the Architecture 2010 version.
Edited on: Fri, Nov 26, 2010 at 3:00:41 PM
Sat, Nov 27, 2010 at 7:27:09 AM | Problem loading custom family
4 Stars: 205 Votes
That symbol appears because Revit can't place that family in that view or in that "Work plane", try in a 3D view and see if you can place it...
Loading a Custom Curtain Wall
Mon, Mar 8, 2010 at 1:24:47 PM
Loading Custom Curtain Wall Panel into file
Mon, Sep 15, 2014 at 9:19:41 AM
Rendering problem with Custon Family
Tue, Mar 11, 2008 at 6:49:58 AM
Problem loading components
Mon, Sep 28, 2009 at 3:43:40 AM
loading custom doors.
Tue, Jan 31, 2006 at 7:07:46 PM
Page generation time: 0.8832
