Forums >> Revit Building >> Technical Support >> Enlarged plan of x-ref
Fri, Oct 28, 2005 at 12:03:26 PM | Enlarged plan of x-ref
pehnc
I have a site plan in AutoCAD which I have already linked into Revit and put on a sheet. I need to do an enlarged plan of the same site plan in the Revit docs. I don't want to resave the AutoCAD site plan as another file in case I modify the orig. and that leaves room for error. I tried making a new CAD file and x-refing the site into it and x-clipping it. When I then link that into Revit, it links but the x-clipping does not work. Is there a way of doing this short of making a whole new AutoCAD file of this Site plan.
Fri, Oct 28, 2005 at 12:17:22 PM | RE: Enlarged plan of x-ref
TomDorner
4.5 Stars: 25 Votes
Just link the site ACAD file into your Revit project. This time don't check the current view only box. Do a callout of the area you want to enlage and you are done. HTH Tom
Fri, Oct 28, 2005 at 1:52:40 PM | RE: Enlarged plan of x-ref
pehnc
Ok, started over like you said but it does not give me the option to uncheck the box for "current view only". It is grayed out and I can't seem to find a way to be able to toggle it. Trisha
Fri, Oct 28, 2005 at 2:44:07 PM | RE: Enlarged plan of x-ref
TomDorner
4.5 Stars: 25 Votes
Trisha, If you already have teh file linked in, you will need to remove the link in the Manage Links and re-link into all views. Tom
Mon, Oct 31, 2005 at 2:19:44 PM | RE: Enlarged plan of x-ref
pehnc
I removed the linked file, saved to central and everything. Technically I have never "checked" the "current view only" box. It has always been grayed out and never an option. How do I get it to become active to uncheck it? Trisha
Tue, Nov 29, 2005 at 1:25:54 PM | RE: Enlarged plan of x-ref
JOYSMIDNIGHT
3 Stars: 1 Votes
IN ORDER TO GET "CURRENT VIEW ONLY" ACTIVE, YOU CAN NOT IMPORT INTO A DRAFTING VIEW. TRY USING A FLOOR PLAN VIEW.
Can't make an enlarged plan
Tue, Oct 28, 2014 at 1:15:22 PM
Enlarged Plan callouts disappear
Thu, Jul 16, 2009 at 12:46:06 PM
Building Section cut appear in enlarged plan
Thu, May 8, 2008 at 11:45:10 AM
Stair Nosing on Enlarged Plan View
Tue, Jan 17, 2012 at 4:32:38 PM
Enlarged Floor Plan Issues
Thu, Jul 25, 2013 at 8:10:51 AM
Page generation time: 1.1934
