37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do I split this object without the void appearing in my second object?
Wed, Nov 24, 2010 at 9:38:57 PM | How do I split this object without the void appearing in my second object?
CRB14
Hi there -
I'm trying to make a spar for a tent structure that is detailed using stainless steel at the top and wood for the spar itself. I need to split or somehow erase the bottom of the stainless detail, (as this is how it has been designed).
I've created a void, but its not related just to the stainless detail - it hides part of the wooden spar when I join the two together which isn't what I want.
 How can I make a horizontal cut into my revolve? Both revolves are tapered...not sure if this is worth knowing or not...see images below:
Many thanks
Thu, Nov 25, 2010 at 4:06:54 AM | How do I split this object without the void appearing in my second object?
4 Stars: 205 Votes
Did you try the "Un-cut geometry" tool? Select the void then select the obj. you don't want to cut.
Thu, Nov 25, 2010 at 2:49:34 PM | How do I split this object without the void appearing in my second object?
CRB14
The uncut geometry doesn't seem to work either - it won't cut or do anything....plus I don't want to uncut anything, I'd like to make the void attach to the lower half of the spar and the void cut the upper half of the spar so that it is split in two parts, rather than 3......any more ideas?
Detail Component Object Style?
Fri, Apr 9, 2010 at 10:01:48 AM
Make void extrusion permanent
Wed, Feb 9, 2022 at 6:46:57 PM
Void Wish
Tue, Mar 3, 2009 at 1:25:21 PM
void behind solid object as dashed line
Wed, Dec 5, 2007 at 8:01:33 AM
Object Style not showing unless object highlighted
Thu, Jun 8, 2017 at 3:29:24 AM
Page generation time: 0.8090
