Forums >> Revit Building >> Technical Support >> Issues with wall sweeps ...
Wed, Nov 24, 2010 at 6:15:12 PM | Issues with wall sweeps ...
iamian33
iamian33 Avatar
I am having a few issues with wall sweeps, I hope that someone can advise ...
1. I am unable to access the "2.Click Modify | Wall Sweeps tabWall Sweep panel  Modify Returns. " command.  The only option I am given, when selecting a sweep (like a gutter) is "add/remove segments"  Please advise on how I can access this option. See attached DOC file ...
2. I have created a 'metal flashing' sweep RFA.  I have added this sweep to a wall family "EW Brick on Stud".  It works fine, except for 2 situations:a. if the wall is attached to the floor/roof above, the sweep disappears, and b. the sweep will not wrap around the end of a this wall segment.  andc. The flashing sweep is cut by windows, but I want to have it continuous.  I have tried to set the sweep to be both cutting and non-cutting, with no success.  The ‘unjoin elements” option will not resolve the issue and I must cancel the operation.
You can see how item 2b takes me to the question #1.  I can not find a way to properly terminate this sweep.
Due to the complexity of the model and the ongoing management of a manually added sweep, I do not wish to add the sweep manually, if at all possible.
Your assistance would be greatly appreciated.thank you
Ian Shafer
Principal Consultant
True North S&F Consultants
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps
Sun, Jul 12, 2009 at 1:54:07 PM
13
Page generation time: 4.2364
