Forums >> Revit Building >> Technical Support >> Titleblock Lineweights
Fri, Oct 28, 2005 at 11:22:16 AM | Titleblock Lineweights
JOYSMIDNIGHT
3 Stars: 1 Votes
I am setting up a new titleblock. I wanted to change the lineweights to thicker lines. I went under line weights and created a new one just for our titleblocks cause its the thicker line and we don't use it anywhere else. But when I select the line I have drawn and go to "Properties-Subcatory" i can't acess my new linetype. What am I doing wrong?
Fri, Oct 28, 2005 at 5:02:34 PM | RE: Titleblock Lineweights
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In a family "object styles" control your linetypes that are available... Add a new object style and then the linetype will be available.
Mon, Oct 31, 2005 at 2:04:43 PM | RE: Titleblock Lineweights
JOYSMIDNIGHT
3 Stars: 1 Votes
Worked liked a charm! Thanks!
Titleblock question
Thu, Jul 2, 2009 at 4:23:14 PM
import lineweights
Wed, Apr 30, 2008 at 9:21:35 AM
Lineweights Issue
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights Question
Wed, Aug 3, 2005 at 4:03:11 PM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Page generation time: 0.3101
