8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Sweep not showing up??
16 Posts No Rating |
I have a 14'-2" high exterior (Brick on Metal stud) wall, I am using a sweep (coping) at the top of the wall. On the elevation it is not showing up? Any clue?
Do you mean the limestone one which is at 14'-1 where as your wall is only 13'-8"???? no wall for sweep to exist on.
On my elevation (attached) it lists the wall as 14'-2", That puzzles me why it dimensions out as 13'-8"?
The wall has either been sketched or the CW is set to embed and it is cutting the wall.
AWESOME, that is what it was, I uncut the Geometry. Can I ask you one more thing? I have the CW that is not rendering as reflective, but as gray. What the heck? (see rendering)
Either you have not assigned the correct material to your panels or your material itself is wrong.
I figured it out.....it was the phasing under view properties. Needs to be set to "Show complete" on the rendering view. thanks and have a great thanksgiving.
Sweep Thickness Not Showing in Section |
Wed, Nov 3, 2010 at 9:42:01 AM
Sweep Problem at roof! |
Sat, Feb 16, 2008 at 8:30:31 AM
Can You Flex a Sweep in Components |
Mon, Jun 3, 2013 at 2:09:23 PM
Host Sweep won't cut thru Windows |
Sun, Nov 9, 2008 at 6:29:55 AM
Wall Sweeps not showing up in phase |
Mon, Mar 25, 2013 at 10:46:05 AM
