17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Aligning window to wall's core exterior
7 Posts No Rating |
Is there a way to align a window to the wall's core exterior? I'm creating some custom window families, and I haven't found a good solution for this. I ended up adding a 'setback' parameter to adjust for, say, a brick exterior, but this doesn't seem like the ideal way.
You need to build your family around a reference plane and use a setback dimension from the face of the wall. HINT- Create the reference plane well to the inside of your wall then label that dimension and build your window. Now flex this window location to something reasonable.
7 Posts No Rating |
Thanks. I think that's basically what I'm doing. So there's no automatic way of doing this?
Walls extend to core boundary |
Fri, Mar 17, 2006 at 8:16:46 AM
Cornice on exterior wall disappears when I place window 2' above it?! |
Mon, Nov 28, 2011 at 2:22:07 PM
Wall Finish |
Wed, Aug 9, 2006 at 6:02:51 PM
Window cuts different size for core and finish layer? (RAC 2010) |
Wed, Oct 14, 2009 at 8:44:54 AM
Problem when Structural Beam meet Wall - Please helps!!! |
Tue, Sep 11, 2007 at 1:41:06 AM
