23 Users Online (21 Members):
Forums >> Revit Structure >> Technical Support >> Column Base Attachements - RS 2011
Working in Revit Structure 2011. I have a column attached to a footing. When the column is selected two options appear regarding column attachements: "Attach Top/Base" or "Detacth Top/Base". I want to detach the column from the footing but Revit directs me to "Select the roof, floor, ceiling, beam, reference plane, or level to wh ich the selected columns should be detached". Unfortunately Revit will not let me select the footing to detach the column from. Is there a way to detach a column from its footing? The only way I can do it is delete the column and redraw.
Column base plate tag units display. |
Mon, Nov 17, 2014 at 2:24:40 PM
Base Plates & Graphical Column Schedules |
Mon, Feb 22, 2010 at 11:51:01 AM
Isolated Foundation atching to column base: Revit 2010 |
Thu, Jun 25, 2009 at 1:59:29 AM
column base constraints |
Mon, Feb 10, 2014 at 8:02:30 AM
Craftsman Column Problems |
Wed, Jun 25, 2014 at 2:16:06 PM
