Forums >> Revit Building >> Technical Support >> Print vector based WITH shading
Sat, Nov 20, 2010 at 2:15:56 PM | Print vector based WITH shading
swegin
I have been trying to figure out how to print to pdf with shodows on, but keep it vector based....everytime i try it I get a popup saying due to the shading it will print it as a rasterized image..... does anyone know a way to overide this setting?
thanks,
Swegin
Sun, Nov 21, 2010 at 8:56:01 AM | Print vector based WITH shading
Shading is not line based so how can you expect to do vector plotting.
Sun, Nov 21, 2010 at 10:08:24 AM | Print vector based WITH shading
swegin
when you export from auto cad as a pdf, everything stays vector based, and the solids become editable filled regions.  so when you open the pfd in illustrator, you can then select the fill and edit it however you want.
Fri, May 4, 2012 at 3:25:40 PM | Print vector based WITH shading
inverted
I'm currently using 2012, and now that 2013 is out, has anyone figured out if you can at least use "consistant colors" (no shading, but with colors) to print color vector? It doesn't seem to work in 2012.
Converting to vector based file types
Sat, Mar 31, 2007 at 8:42:02 PM
Vector Printing
Wed, Jan 14, 2015 at 12:41:14 PM
vector vs. raster(revit2008)
Wed, Mar 22, 2017 at 5:51:15 AM
Vector printing and rasterized transparency
Thu, Jul 25, 2013 at 4:59:33 AM
Printing vector changes solid to hidden line, shaded areas don't show correctly
Mon, Apr 20, 2015 at 10:56:21 AM
Page generation time: 1.8131
