Forums >> Revit Building >> Technical Support >> Titleblock Parameters
Thu, Oct 27, 2005 at 3:16:13 PM | Titleblock Parameters
JOYSMIDNIGHT
3 Stars: 1 Votes
I have all of my titleblock setup except I can not figure out how create additional label parameters other than the standard ones. I went under "Shared Parameters" and created 5 new ones but when I place a label on my titleblock with those parameters, bring into my project, it will not allow me to edit the parameters I added. It will only allow me to change the parameters that were from the standard list. We have 5 places to enter "Revision Descriptions" on our titleblocks. These are the ones I am trying to create. I wanted it to appear like the attached image. This is our AutoCAD sheet but I am trying to match it in Revit. Any ideas would be greatly appreciated.
Thu, Oct 27, 2005 at 5:24:41 PM | RE: Titleblock Parameters
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to load the shared parameters into your template and project in order to make use of them... Settings--Project Parameters--Add--Shared Parameter--Select parameter (can only do one at a time)--Select whether you want an instance or type (assuming instance...)--Then select what families you wish to apply to, you can either use project information or drawing sheets... HTH.
Mon, Feb 26, 2007 at 1:05:58 AM | Titleblock Parameters
MD01
I have done all these things and my parameters show in Project Information and a re Editable but they are still not showing in the Titleblock itself.  The information is still shown as a ?.  Please help because I have been trying to solve this issue for days now.
Mon, Feb 26, 2007 at 9:01:55 AM | Titleblock Parameters
Elmo
3.5 Stars: 4 Votes
Those questions marks mean that you have setup your titleblock correct and you now need to put the info you want into the box.
Mon, Feb 26, 2007 at 9:27:29 AM | Titleblock Parameters
coreed
coreed Avatar
4 Stars: 16 Votes
if you want a person to know what to type at the blue ? mark. i think you will have to add that as a text note
(Drawn By : ? ) you will have position the two notes to get the desired effect
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Feb 26, 2007 at 11:35:52 PM | Titleblock Parameters
MD01
Thanks for the response I did finally get it right.  I did forget to indicate in my comments that the ?'s where red not blue.  Any way problem sorted.
Mon, Oct 15, 2007 at 3:32:37 PM | Titleblock Parameters
rickdputo
i'm spinning my head too and i need your help.  Same issue here, I did the parameter thing and the share thing, but my labels are still coming in red as a question mark.  Attach is the file - I am very new to this, but I am approaching it with an open mind.  Please help
Wed, Oct 17, 2007 at 9:52:36 AM | Titleblock Parameters
Elmo
3.5 Stars: 4 Votes
Rikcdputo just make sure that you load the shared parameter into your project as well. Go to Settings>Project Parameters to load them in.
Thu, Oct 18, 2007 at 7:30:09 AM | Titleblock Parameters
rickdputo
I've loaded the parameters, but i'm still getting the red (?) and it doesn't allow me to edit the field.
Thu, Oct 18, 2007 at 7:44:12 AM | Titleblock Parameters
rickdputo
Fri, Oct 19, 2007 at 7:21:18 AM | Titleblock Parameters
#11
Elmo
3.5 Stars: 4 Votes
When you imported the parameter did you select drawing sheets catogery? This is the only ohter thing that I can think of that you could be missing.
Mon, Oct 22, 2007 at 3:18:02 PM | Titleblock Parameters
#12
rickdputo
drawing sheets catogery - that's was it!  thanks for your help
Thu, Jan 10, 2008 at 4:59:55 PM | Titleblock Parameters
#13
Brockster
I was also having problems not being able to edit a label of the titleblock once added to the project. Mr. Shot's comment dated Thu, Oct 27, 2005 at 5:24:41 PM fixed my issue. Thanks for the help!
Fri, Jan 11, 2008 at 9:09:28 AM | Titleblock Parameters
#14
rickdputo
you have make sure that you check the "DRAWING SHEETS" under the Categories - see mr. spot's reply below
Fri, Jan 11, 2008 at 9:11:03 AM | Titleblock Parameters
#15
rickdputo
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
How to link shared family parameters into an assembly titleblock?
Mon, Apr 20, 2015 at 8:14:15 AM
Mon, Mar 19, 2007 at 11:12:52 AM
Drawn By and Checked By titleblock parameters
Fri, Oct 10, 2008 at 10:43:12 PM
Tue, Apr 19, 2005 at 11:55:06 AM
Page generation time: 0.6672
