Forums >> Revit Building >> Technical Support >> mass from walls- is it possible?
Fri, Nov 19, 2010 at 1:13:37 AM | mass from walls- is it possible?
RoiH
hi
i know i can create walls by face- but is it possible to create a mass from a building i create in the regular way??
i only need the the outline of the building so i can wrap it with curtain wall.
i really need a solution asap- im an architecture student and its for a new project i got
thank you very much
Fri, Nov 19, 2010 at 6:30:04 AM | mass from walls- is it possible?
If you have regular walls and want them to be curtain walls, just swap them out.  You don't need a mass to use curtain walls.
Fri, Nov 19, 2010 at 7:08:13 AM | mass from walls- is it possible?
RoiH
i need the mass for the shape- its can be usfull for so many other things - and i need to keep the walls i already built...
so ill ask again- is there a way to make mass out of objects such as walls ??
thank you
Fri, Nov 19, 2010 at 7:30:05 AM | mass from walls- is it possible?
No
walls disassociated with mass - can't update walls
Fri, Nov 2, 2012 at 10:51:18 AM
Tops of the walls applied to mass looks horrible
Mon, Jan 5, 2015 at 10:45:47 AM
Mass and walls are squiggled
Tue, May 5, 2009 at 2:23:00 PM
How to attach top/base - walls to mass roof
Tue, Sep 22, 2015 at 3:18:05 PM
Need HELP creating walls from mass
Wed, Nov 7, 2012 at 6:35:21 AM
Page generation time: 0.3930
