Forums >> Revit Structure >> Technical Support >> revit to autocad-dwg to pdf
Thu, Nov 18, 2010 at 10:12:43 PM | revit to autocad-dwg to pdf
lightshadows23
I do the scale drawings (elevations.plans,sections) export to dwg and put them on autocad to make the lines abit better adn then i print to file as pdf to do on photoshop. i dunno if this doesnt work but it seems logical
although..
when the file is in autocad is perfect scale like it was in revit too. after when i export to pdf while its supposed to be 420x 297mm canvas size it opens as other size:S (not much different but still wrong)
and I do can change it after but when i open other blank paper- bigger lets say- and drag it there its all messed up again and looks bigger than the page which is smaller:S its really weird
i ve been doing autocad to pdf alot of times and it worked great. is it prob that i use revit 2010 and autocad 2007?
this is kinda frustrating ..has this happened to anyone before? please help cause this is too complicated and couldnt find asnwer
Fri, Nov 19, 2010 at 3:38:26 AM | revit to autocad-dwg to pdf
4 Stars: 205 Votes
Look at the bottom of this page, you will see similar questions.
Fri, Nov 19, 2010 at 6:33:07 AM | revit to autocad-dwg to pdf
Why do you export to autocad?  "... put them on autocad to make the lines abit better ..."  This doesn't make sense.  You can change all the linework you need in Revit.
Fri, Nov 19, 2010 at 9:33:56 AM | revit to autocad-dwg to pdf
lightshadows23
WWHub: I mean to fix some problems while its 2D , to cut the specific extend i want etc.
and revit doesnt have pdf plot either.. so I have to make it into dwg anyway..
the problem is the scale which is wrong.but ill try cute pdf Typhoon and write back what happened with scale:/
Fri, Nov 19, 2010 at 10:18:46 AM | revit to autocad-dwg to pdf
You can crop any view in Revit.  Still don't understand why going to cad.
We use cutePDF and it works great from Revit.
Fri, Nov 19, 2010 at 10:19:03 AM | revit to autocad-dwg to pdf
lightshadows23
i mean autocad is useful to remove some overrides- and there are alot believe me
on revit I cant just delete lines..
I dont udnerstand ,do i have to export to dwg or not?
Fri, Nov 19, 2010 at 10:22:14 AM | revit to autocad-dwg to pdf
lightshadows23
I can do it directly from revit? how:/ can you explain?
its just my lines come in all different colors and overrides i already explained(like walls openings still show).also some dotted dont appear still.
this is worst could happen cause i did all modelling and now i cant get it right the final step arghh
Fri, Nov 19, 2010 at 10:23:57 AM | revit to autocad-dwg to pdf
You write:  "...on revit I cant just delete lines.."   Do you know about the linework tool and "INVISIBLE LINES"?  Obviously you don't.  Modify tab - linework tool - choose invisible line and pick the lines you want to hide.
Still no reason to export to CAD.
Fri, Nov 19, 2010 at 10:40:55 AM | revit to autocad-dwg to pdf
lightshadows23
aaa thats great thank youSmile
 just that windows dont show on 2nd floor still adn the section tag is tiny
Fri, Nov 19, 2010 at 10:55:34 AM | revit to autocad-dwg to pdf
lightshadows23
ill just underlay and put invisible line what i dont want:, that solves everything
thanks again":D
Fri, Nov 19, 2010 at 5:08:45 PM | revit to autocad-dwg to pdf
#11
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Open that window family, and choose on visibility settings "show only if instance is cut" . Im guessing its a custom window.
Mon, Mar 20, 2017 at 3:11:13 AM | revit to autocad-dwg to pdf
#12
caffiles
try download from http://www.pdftoflashconverter.com/dwg-to-pdf.htm       support auto 2017
dwg to pdf
mxf
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:03 AM
Autocad imports PDF's. Is there anyway Revit does that?
Mon, Feb 1, 2010 at 5:06:18 PM
revit dwg into autocad
Tue, Apr 27, 2010 at 11:13:41 AM
PDF - DWG, DWG - PDF
Mon, Jan 26, 2015 at 11:15:56 PM
Print to PDF sheets with DWG files on them help. Maybe Bluebeam help
Mon, Oct 26, 2015 at 10:55:35 AM
Page generation time: 1.3472
