Forums >> Revit Building >> Tips & Tricks >> Corner boards
Thu, Oct 27, 2005 at 2:26:36 PM | Corner boards
lwasden
Hi~ Im trying to make my corner boards miter or atleast match up on the corner evenly. Any ideas?
Thu, Oct 27, 2005 at 3:01:21 PM | RE: Corner boards
TomDorner
4.5 Stars: 25 Votes
This is a corner board family that is wall hosted. It will sit over whatever the outside layer of your wall is. The next post will have the non-hosted version to sit against the sheathing layer of the wall. Tom
Thu, Oct 27, 2005 at 3:03:14 PM | RE: Corner boards
TomDorner
4.5 Stars: 25 Votes
This is non-hosted version. You can turn your view res to medium to see the layers in your wall and place this so it sits over the sheathing layer, but not the siding. Use the join geometry command to keep siding from going through the corner board. Tom
Fri, Apr 21, 2006 at 11:38:12 PM | RE: Corner boards
ICON
5 Stars: 3 Votes
New to Revit, but I've just created an in-place component, extrusion type, in an "L" shape that matches the size of the corner boards. I assume you're talking about the verticle 1x4 that siding butts against. Seems to work fine, you can adjust the height very easily from the elevations. Not sure if this is the best way, but seems to work fine for as little as I understand about the software. Randy Icon Residential Post edited on 2006-04-21 23:39:47
REAL Corner boards
Thu, Oct 27, 2005 at 3:51:59 PM
What is the best way to create corner boards?
Fri, Apr 13, 2007 at 3:34:11 PM
corner boards
Sun, Dec 18, 2005 at 4:50:54 PM
Skirting boards
Tue, Dec 15, 2015 at 3:36:54 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 2.1398
