Forums >> Community >> Newbies >> dual entry stair
Thu, Nov 18, 2010 at 10:23:39 AM | dual entry stair
imsok3wl
i am trying to create a stair case that starts as 2 seperate runs, joins at a landing and then finishes its run as 1 run. it is an atrium stair. i have modeled what i want in autocad but i don't know how to get that into revit nor do i know how to make revit do the stair i want. i have created half of the stair in revit but if i mirror the run of stairs it thinks its a new flight and goes in the wrong direction. i know the floor plates aren't the same in the revit drawing...that's not an issue. but if anyone can help with the stair that'd be great. thanks
Thu, Nov 18, 2010 at 10:39:20 AM | dual entry stair
You need to do this as three stairs and an intermediate "floor" that is your landing.
Sun, May 29, 2011 at 11:05:33 AM | dual entry stair
shiva1507
Other simple option is to do half the stair and mirror it....
you will see the the line at the mirror axis where both stairs mergre, you can easily go to modify and line work tool and make it invisible line,
you need to fiddle around with railing after that...it should work.
Please let me know .....
dual entry stair
Sun, Jul 14, 2013 at 9:34:27 PM
AMD DUAL CORE V INTEL DUAL CORE PROCESSORS [ 1 2 ]
Wed, Jan 25, 2006 at 2:00:11 AM
15
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Roof Covered Entry Problem
Mon, Jan 31, 2011 at 1:58:30 PM
keyboard entry for inserting details or "blocks"
Mon, May 4, 2009 at 6:43:25 PM
Page generation time: 0.0898
