Forums >> Revit Building >> Technical Support >> Door tag switches visibility parameter automatically
Wed, Nov 17, 2010 at 8:12:50 PM | Door tag switches visibility parameter automatically
bert
Hello,
At our office, we had a brilliant ‘what if’ idea for a door tag, which now seems it’s not possible, so I was hoping that by sharing this idea, perhaps somebody could come up with a solution.
We have a door tag in which one of the labels reads the fire rating of the door. The label then displays for instance “RATED 20-MIN” which is really nice, except when we get an unrated door it reads “RATED 00-MIN” which is just a bit silly. We were hoping there’d be a way for the tag to automatically use visibility parameters and display “UNRATED” if the rating is zero. If it is anything but zero, it’ll read “RATED XX-MIN”. The actual rating could be the label, and the “UNRATED” could be text.
Here’s where I’m stuck, inside the tag family I’m not able to call in the Fire Rating parameter. So I can’t use any formulas to use the visibility parameters.
I’m really curious about this one, so hopefully you can help us out.
Thanks for reading!!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Wed, Nov 17, 2010 at 8:17:46 PM | Door tag switches visibility parameter automatically
bert
I just went through my old posts, as it turns out I asked something similar over a year ago (and forgot about it).
Don't stop trying it out though. Smile
http://www.revitcity.com/forums.php?action=viewthread&thread_id=16530
using RAC-2013
Door Tag driven by door parameter.
Tue, Jun 28, 2011 at 12:01:00 PM
Visibility elements in a room tag
Mon, Aug 9, 2010 at 2:58:33 PM
Using a Yes/No Parameter to control the visibility of another Label in a Tag
Wed, Feb 6, 2013 at 2:03:21 PM
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:09 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Page generation time: 0.4240
