Forums >> Revit Building >> Technical Support >> Plan display wihtout wall finishes
Tue, Nov 16, 2010 at 8:37:45 PM | Plan display wihtout wall finishes
Sydney2001
Hi Revit Citizens,
I was hoping to make a concrete and brick setout drawing for the builder and I was wondering if there is an easy way to produce a plan that doesn't show the wall finishes, as these will not be required for some time in the building process.
thanks again.
Syd
Wed, Nov 17, 2010 at 3:59:13 AM | Plan display wihtout wall finishes
matthewh75
3 Stars: 3 Votes
Why not duplicate the main plan, set the detail level to coarse to make all the walls a solid fill & then use that as a set out drawing?.
If you want the wall leafs shown without the hatching use Visibility Graphics & override the Cut Pattern for the Wall category
Wed, Nov 17, 2010 at 3:31:13 PM | Plan display wihtout wall finishes
Sydney2001
Hi there Mathewh
THank you for you input, no doubt it will help.
After having slept on it I now realise that your suggestion coupled with tweaking the options for the dimension tool is the right way to go.
thanks
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Wall Finishes Tag
Mon, Jun 3, 2013 at 9:21:53 AM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Wall Display in Plan
Wed, Jan 13, 2010 at 12:30:59 PM
Page generation time: 3.4086
