Forums >> Revit Building >> Technical Support >> rendering light through curtain walls
Mon, Nov 15, 2010 at 3:41:31 PM | rendering light through curtain walls
erisix
I have not been able to get my curtain walls to renders as transparents so that light comes in through them. my portals are all on, the wall geometry has been cut, I have tried interior sun and interior sun and artifical. I am using Revit 2011 educational version.does anyone know how to fix this?
Thanks
Tue, Nov 16, 2010 at 3:31:24 AM | rendering light through curtain walls
4 Stars: 205 Votes
After the render, in the render dialog box, you have a "Adjust Exposer" button, change this values and see if your image appearence change too.
Tue, Nov 16, 2010 at 3:54:06 AM | rendering light through curtain walls
erisix
I solved the problem by managing the materials for the entire project. glass was not set to render as transparent. thanks for your reply.
Rendering light sources within a custom curtain wall panel
Mon, Sep 26, 2011 at 2:59:09 PM
Rendering - light blub missing
Fri, Nov 4, 2011 at 1:08:08 PM
Rendering - curtain walls
Mon, Jun 5, 2006 at 8:04:39 AM
Rendering And Light Settings Revit 2009 [ 1 2 ]
Tue, Oct 20, 2009 at 3:06:23 AM
26
Rendering light trouble...
Thu, Sep 16, 2010 at 9:33:24 AM
Page generation time: 5.8994
