Forums >> Community >> Newbies >> Duct Elbows - Radius to Big
Mon, Nov 15, 2010 at 9:46:41 AM | Duct Elbows - Radius to Big
FISHMRF
I am trying to as-built some of our existing jobs to practice learning Revit MEP...
When I draw an elbow the radius is much to big...is there a way you can change this within Revit so it always draws the way I like?
Thanks
Mon, Nov 15, 2010 at 3:50:20 PM | Duct Elbows - Radius to Big
jackhoward
Click on the elbow and in the properties menu, click on the graphic with the description of the elbow and change the size to either 1D or 1.5D depending on how small you wish to go.  If you want to make one of these default, click on a duct that you are using, i.e. round duct - taps, and hit edit type again, and in that menu there is an option to switch the default elbow for the duct type to 1D, 1.5D or 2D.
Hope this helps,
Jack
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Elbow and tee's duct surface area
Mon, Feb 27, 2012 at 6:42:05 PM
Capping a Duct
Tue, Jan 21, 2014 at 9:46:17 AM
Piping families...
Fri, Jul 13, 2018 at 8:48:03 PM
Duct fitting material area MEP 2012
Wed, Sep 26, 2012 at 11:05:12 AM
Page generation time: 0.0816
