Forums >> Revit Building >> Technical Support >> Text scaling
Sun, Nov 14, 2010 at 2:58:42 AM | Text scaling
Travatine1
How do I get Revit to adjust text size automatically when I change from a drawing of say 1:100 to a new drawing 1:20?
Sun, Nov 14, 2010 at 6:14:23 AM | Text scaling
seyedsaleh
seyedsaleh Avatar
revit always atumaticly when you change the scale changes the text size,
but if you want to change the text size-select it and then go to it's propertie,from there you can change the size and styles.
good luck
seyedsaleh@gmail.com
 0098 912 77 111 35 (tehran-iran)
0097 150 90 60 879 (dubai)
Sun, Nov 14, 2010 at 8:23:15 AM | Text scaling
This is one of the great things about Revit.  Text size in Revit is fixed to paper space dimensions regardless of view scale.  1/8" text is physically 1/8" in every view when printed.
If you want different sized text, create a new style and change all your text to that.
scaling text and dimension according to the scale of view
Fri, Aug 29, 2008 at 10:26:28 AM
Revit Scaling with 27" UHD Monitor
Fri, Nov 25, 2016 at 12:42:48 PM
Elevation Level Scaling
Mon, Apr 24, 2006 at 2:41:41 PM
Export to DWG - Text Scaling
Mon, Feb 4, 2008 at 4:01:11 PM
Scaling Mess Ups
Mon, Apr 24, 2006 at 9:20:26 AM
Page generation time: 1.7130
