Forums >> Revit Building >> Technical Support >> Lighting Plan - How to
Wed, Oct 26, 2005 at 3:18:05 PM | Lighting Plan - How to
Ace001
I need to create a lighting plan, and was beginning to use the cieling plan as it sowed all my lights, but the swithches don't show up in the RCP. What do you do? Thanks
Wed, Oct 26, 2005 at 4:02:17 PM | RE: Lighting Plan - How to
TomDorner
4.5 Stars: 25 Votes
Make sure that the switch category is on in your view and that you set your cut plane low enough to cut through them. As switches are on in the same category as all electrical fixtures you will find any outlets that are high enough on the wall to be cut by the cut plane will show up as well. Our firm used to show the switches on the RCP, but with Revit we discontinued that practice. HTH Tom
Electrical/Lighting plan [ 1 2 ]
Wed, May 13, 2009 at 11:27:51 PM
16
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:38 PM
Can't figure out how to insert Recessed Can lighting into ceiling plan
Mon, Aug 16, 2010 at 12:50:05 PM
Combined Electrical and Lighting Plan
Mon, May 19, 2008 at 2:29:00 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting
Tue, Sep 13, 2011 at 11:12:09 AM
Page generation time: 0.6731
