15 Users Online (13 Members):
Forums >> Community >> The Studio >> Customizing Families and objects
1 Posts No Rating |
I know that I can customize my own family by opening it as its own seperate file. But I am curious if there are any other methods to doing so. Can I customize with a different program in import into Revit. A problem I find with the current way of customizing is that it is a time comsuming process.
Revit families can only be developed or changed in the family editor which is integral to the Revit program. A properly desinged family however will let you creat another instance of itself by duplicating, naming it and then changing the parameters that the family contains. For example, a door that has 36" x 7'-0" size but not 36" x 8'-0" size can be made into the larger size by going to the properties of the smaller one, duplicating it and changing the height parameter to 8'-0".
Another option is that 2D and 3D CAD geometry can be brought into a family.
HTH
Tom
Converting ArchiCAD objects into Revit families |
Thu, Jan 17, 2013 at 9:43:29 AM
Transparent Families |
Thu, Jul 15, 2010 at 8:35:26 PM
Multidirectional moving of objects w/in families |
Mon, Jun 28, 2010 at 9:08:35 AM
How to Scale Objects in Revit |
Fri, Aug 25, 2017 at 1:13:47 PM
Revision Numbering |
Wed, Jun 17, 2015 at 12:39:24 PM
