Forums >> Revit Building >> Technical Support >> How can I make a parametric Profile?
Thu, Nov 11, 2010 at 10:21:56 AM | How can I make a parametric Profile?
aspect
5 Stars: 2 Votes
Just wondering if anyone knows how to make a parametric profile to use when doing sweeps? For example I can make a simple 40mm round profile and use it to create a handrail, or an L-shaped profile 150mm x 100mm and use it for a roof flashing, or a 90mm X 19mm rectangle for skirting boards, etc.
But is it possible to make the parameters of a profile changeable? so when you load a profile, it is a single 'shape' with unlimited sizing options - eg. my round profile could be 1mm Diameter to 100000mm Diameter...architrave of multiple sizes, etc
There doesnt appear to be anyway to dimension and add a parameter to a shape when created in the family profile editor.
Anybody got any ideas?
www.aspectarch.com
Thu, Nov 11, 2010 at 10:48:55 AM | How can I make a parametric Profile?
matthewh75
3 Stars: 3 Votes
The family editor in R09 has parametric abilities as far as I can tell?
Thu, Nov 11, 2010 at 11:16:52 AM | How can I make a parametric Profile?
aspect
5 Stars: 2 Votes
Cheers Matthewh75,
its weird because I can create a profile with instance parameters to change sizes, but when I load into into a project and add the profile to a sweep, the parameter options dont seem to appear anywhere.
Attached is a flashing profile as an example. If you can figure out how to make the parameters appear in the project, (somewhere in the 'edit sweep' section I'm sure - it would be great.
www.aspectarch.com
Thu, Nov 11, 2010 at 11:25:39 AM | How can I make a parametric Profile?
matthewh75
3 Stars: 3 Votes
I can't open the file, I'm on R'09 Sad
You need to alter the parameters within the 'Families' drop down under 'Profiles' in the project browser tree - find the profile you need & adjust/replicate there, then use that adjusted profile to create your new sweep - sorry I can't be of more help, we just need to upgrade to 11! Smile
Thu, Nov 11, 2010 at 11:40:59 AM | How can I make a parametric Profile?
aspect
5 Stars: 2 Votes
Cheers Matthewh75,
www.aspectarch.com
Profile Parameter
Wed, Apr 28, 2010 at 11:15:54 AM
Parametric sweep profile?
Mon, Jul 17, 2006 at 8:32:12 AM
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
how to make Parametric array in families. revit2011
Wed, Oct 19, 2011 at 10:53:11 PM
Nested parametric profile in fascia
Mon, Dec 22, 2008 at 11:24:00 AM
Page generation time: 1.0598
