Forums >> Revit Building >> Technical Support >> spot elevations - lay-in ceiling
Wed, Oct 26, 2005 at 9:20:54 AM | spot elevations - lay-in ceiling
swarch
when placing the elevation symbol on the RCP the elevation indicates the top of the ACT grid. how can this be modified to indicate the bottom plane or actual ceiling height?
Wed, Oct 26, 2005 at 5:51:59 PM | RE: spot elevations - lay-in ceiling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
- I think your referring to a spot elevation? instead use a ceiling tag to show the ceiling level... HTH.
Thu, Oct 27, 2005 at 2:49:21 PM | RE: spot elevations - lay-in ceiling
swarch
oh.......never mind. Thanks for your feedback...i appreciate your involvement in this site. From families to forum to I use much of your info.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
8 side pyramid lay-in ceiling. Help.
Tue, Aug 28, 2007 at 2:07:44 PM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Spot dimensions for Bottom of Ceiling elevation, not top of ceiling frame
Tue, Jun 13, 2006 at 11:14:40 AM
Page generation time: 3.3282
