Forums >> Revit Structure >> Technical Support >> HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
Sun, Nov 7, 2010 at 3:10:54 PM | HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
CRB14
I've got Revit 2011 installed on my computer and need to drop in some 'readymade' furniture off websites. Only problem is that these files are either 3DS files or DXF files. I do not have AutoCAD or any other 3D programs installed, so cannot open and change the type of file that they are.
What is the best way to go about getting these files into a format whereby I can open them in Revit? Do they need to be saved as .rvt files or what? I notice there is no 'IMPORT' selection in Revit.....
 If I need to download some kind of program to do this, please let me know,
 Thanks!
Sun, Nov 7, 2010 at 6:21:00 PM | HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
rkitect
rkitect Avatar
4 Stars: 29 Votes
DXF can be imported through the Insert > Link CAD > Choose Cad File then select DXF from the file type in the import dialog.
I don't have Revit in front of me but I'm pretty sure you can still not directly import 3DS into revit.  You will need to export from 3DS to either DWG, DXF, ADSK or there's another option that I'm failing to remember right now.  I'll check it later when I'm making my videos.
How to get 3DS files into Revit?
Mon, Aug 29, 2011 at 11:45:25 AM
Importing Cad Files
Tue, Mar 31, 2009 at 8:36:59 AM
.ies files from Revit export to 3Ds Max rotate incorrectly
Wed, Aug 19, 2009 at 2:06:14 PM
is there a way to import a revit family into 3ds max?
Fri, Oct 8, 2010 at 4:28:15 AM
import 3D model in DXF or DWG - how use it?
Mon, Oct 31, 2005 at 9:28:45 AM
Page generation time: 2.8989
