Forums >> Revit Building >> Technical Support >> Stepped Footing
Sat, Nov 6, 2010 at 10:49:39 AM | Stepped Footing
letsgotigers
I have a wall footing that changes elevation - it steps down 16" at one point. I was able to drop the footing by using Split command and modifying the base height of the foundation wall. The only issue now is that the footing is not continuous; it stops at one height and picks back up at the lower height, with no vertical "step" to make the footing continuous. How do I create the vertical step in the footing, so that it's a continuous, stepped footing?
Sun, Nov 7, 2010 at 6:58:23 AM | Stepped Footing
jarosa
jarosa Avatar
4 Stars: 5 Votes
I use an in place family. Here's a video from DG
http://therevitkid.blogspot.com/2010/02/tutorial-stepped-footing-revit-rocks.html
Sun, Nov 7, 2010 at 7:35:38 AM | Stepped Footing
If your footing is attached to the bottom of the wall and you edit the sketch of the wall to step its bottom, the footing will step with it.
How to Create Stepped Footings
Wed, Mar 25, 2015 at 12:30:37 PM
Stepped Footing CADclip Tutorial
Wed, Feb 10, 2010 at 3:37:09 PM
Rebar in Stepped Footing
Mon, Dec 7, 2009 at 9:21:16 PM
Stepped Roof with Overhand
Fri, Oct 25, 2013 at 10:40:43 AM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Page generation time: 0.1380
