Forums >> Revit Building >> Technical Support >> Wrapping a wall type at bottom of wall
Fri, Nov 5, 2010 at 2:32:00 PM | Wrapping a wall type at bottom of wall
letsgotigers
In a revit model, I have an exterior beam wrap (at front porch) that I created as a wall type. It's basically 5 1/2" wood studs with 1/2" plywood sheathing and 1/2" finish trim on each side. Is there any way to wrap the bottom side of the wall (or the beam wrap in this case) with the sheathing and trim to close off the bottom side? You can wrap the inserts and ends in Edit Assembly, but I don't see a way to wrap the top or bottom surfaces.
 Thanks.
Sun, Nov 7, 2010 at 7:46:40 PM | Wrapping a wall type at bottom of wall
rkitect
rkitect Avatar
4 Stars: 29 Votes
Unfortunately wrapping top and bottom is severely lacking in Revit.  You may want to try split surface tool combined with paint to get the desired results.
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
Brick will not wrap to new wall type
Thu, Apr 28, 2011 at 10:18:56 AM
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
Wall wrapping
Thu, Aug 30, 2007 at 10:19:20 AM
Page generation time: 8.0421
