Forums >> Revit Building >> Technical Support >> wall/floor - in section view
Wed, Oct 26, 2005 at 6:45:15 AM | wall/floor - in section view
malex
when I have composite walls or floors I would like the concrete structure to have a thicker line and other layers (insulation, brick, wood floor....) to be thinner... for example, in a section view the floors have thick lines on top and bottom (bottom line is the concrete slab, top line is the wood floor)...is it possible to change settings so that both lines of the concrete slab are thicker and other lines (including the wood) thin? the same problem is with walls in plan view...... detail level is set to fine I can use the Linework tool but is there a way to make these settings in the family itself?
Wed, Oct 26, 2005 at 6:11:21 PM | RE: wall/floor - in section view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check out host override cut styles in your visibilty settings. Here you can change line types via their layer in the wall... This should enable you some of what you require. Once you have it setup the way you want, save as a view template and apply to other appropriate views. HTH.
Thu, Oct 27, 2005 at 2:58:13 AM | RE: wall/floor - in section view
malex
great! thanx!
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Wall Floor join in section
Sun, Jan 30, 2011 at 9:19:31 AM
The option to create Wall section not showing up, only building section.
Wed, Jan 23, 2013 at 3:16:46 PM
Sloped Floor Deck in Section View
Mon, Nov 28, 2011 at 3:13:11 PM
Model view section cut refer to a drafting view
Wed, Nov 13, 2019 at 5:44:08 AM
Page generation time: 3.2165
