26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> PFC + horizontal plate beam
1 Posts No Rating |
Hi all, I want to create a window lintel on brick veneer wall with includes a PFC and a horizontal plate welded to bottom flange of PFC, but I don't know how to do it. Could anyone show me how to do it please? Besides, I am doing first floor framing plan which shows walls/openings/columns under (belong to ground level) and also framing members (beams/floor joists...) of first floor. I also need to show columns/posts over (belong to first floor level) as halftone to indicate the point loads over which must be supported by these framing members. I don't know which plan I should use as a main plan. I want to use ground floor plan as the main one, but then I can't see the framing members which are on the the level between ground ceiling and first floor. Could anyone help me with this? Thank you a lot.
Ha, K |
PFC rotating |
Mon, Aug 18, 2008 at 1:48:58 PM
Detailing a Beam Saddle at Valley Beam |
Wed, Jan 26, 2011 at 12:15:21 PM
Mirroring PFC |
Mon, Jun 11, 2012 at 9:51:39 AM
CONNECT ENDPLATE FROM PFC TO PLATE WELDED TO FLANGE ENDS OF A UB |
Wed, Apr 19, 2017 at 6:55:11 AM
plate not saving |
Fri, May 2, 2025 at 1:22:19 PM
