Forums >> Community >> Newbies >> printing to scale
Thu, Nov 4, 2010 at 6:53:00 PM | printing to scale
ECdes
I have read the documentation I have looked at tutorials etc. What I want to do is print to scale without a title block. Thanks
Fri, Nov 5, 2010 at 7:13:33 AM | printing to scale
You want the scale in the titleblock of the sheet?  Obviously a sheet can have many views, all with different scales, so Revit has no way of knowing which one to pick.
If you want this, add a parameter to your titleblock that you fill in.  Or, create multiple titleblocks, each with a different scale shown and you pick the correct one when you need it.
Fri, Nov 5, 2010 at 10:06:42 AM | printing to scale
gdoherty0102
3 Stars: 2 Votes
You cant really do this...the way that I got around it was to create a blank title block at the paper size you want to print on...ie create a 8.5x11 "Title Block" that only has the 4 lines that create the rectangle shape of 8.5x11 then place the view on that and print it.
Printing to scale and not using a title block can't really be done that I am aware of.
Fri, Nov 5, 2010 at 10:42:24 AM | printing to scale
TKennedy
4 Stars: 8 Votes
Do you mean printing a view without placing it on a sheet? If so, just send it to the plotter as you normally would. Don't use Fit to Page in settings, and set the Zoom to 100%. That's what I've been doing, and it works fine.
Fri, Nov 5, 2010 at 10:44:17 AM | printing to scale
gdoherty0102
3 Stars: 2 Votes
Kennedy,
How do you know what your going to get though?  That has always been my issue.  If I just need a portion of a plan on 8.5x11 to scale I could never get it to print the area I wanted without placing it on a sheet.
Fri, Nov 5, 2010 at 12:17:57 PM | printing to scale
gdoherty0102,
If you want to print just a portion of a view that is 1/4" scale at 1/2" scale - then change the view scale, move the view crops, print the view and undo all your changes.
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale.
Tue, Sep 6, 2011 at 7:51:06 AM
Printing
Tue, Oct 5, 2010 at 6:38:41 PM
Printing views to scale?
Fri, Aug 31, 2007 at 8:33:25 AM
Printing an A1 sheet
Mon, Mar 18, 2013 at 3:21:14 PM
printing in revit
Thu, Oct 22, 2009 at 10:26:33 AM
Page generation time: 0.8948
