Forums >> Revit Systems >> Technical Support >> Multiple Connections One Family
Thu, Nov 4, 2010 at 2:57:08 PM | Multiple Connections One Family
mlennon
Hi there,
i've created a family that will act as a service carrier for multiple water and gas systems in Revit MEP 2011 (High Purity Water Loop, Chilled Water Supply and Return, and 4 diffent gasses) I've made all of these connections at the top of the family and am attempting to add this one compents to the multiple different systems i've created in the project. My problem is that when i try to add this component to the second system it will not highlight and allow me to add it. Can this component be part of several different systems? Very frustrating... attached is the family i'm working with.
Any help is greatly appreciated. Thanks!
Sun, Nov 7, 2010 at 7:58:51 PM | Multiple Connections One Family
rkitect
rkitect Avatar
4 Stars: 29 Votes
Without having MEP in front of me it's hard to test the family with systems.  Looking at the family, the only thing I see that may give you fits is all of the "Other" connectors.  Let me play with this family a bit when I get into the office where I have MEP to see if I can remember what the trick is to multiple systems with the "other" connector is.
Precast embed connections
Wed, Jul 30, 2008 at 11:22:13 AM
Revit 2018/2019 Steel Connections
Thu, May 10, 2018 at 8:05:17 AM
RAC 2012: Creating, Tagging, Scheduling Wood Joist Connections with 2d Family
Wed, Jun 6, 2012 at 9:07:31 AM
Structural Connections / Mechanical Fixings
Tue, Nov 10, 2009 at 4:20:53 AM
plumbing connections
Sun, Oct 4, 2009 at 6:25:39 AM
Page generation time: 1.2246
