Forums >> Revit Building >> Technical Support >> Horizontal railing spacing problem
Thu, Nov 4, 2010 at 2:23:40 PM | Horizontal railing spacing problem
CDWdavid
5 Stars: 5 Votes
I created a pipe railing as attached. If I'm using 3-7/8" along the first flight, then at the landing the space between top and middle rail would exceed 4" and not comply with the code. if the space at the landing is less than 4", then the top two rails became too close on sloped portions, and ugly. The only way that I can make it work was to create three seperated railings which is too tedious, since the angles for two flights are slightly different. Help!
Thu, Nov 4, 2010 at 2:47:22 PM | Horizontal railing spacing problem
Your railing doesn't make sense.  The handrail should be inside the guard and the ballusters would end at a rail - not the handrail.
BTW - you can always have two different rails in the same location.  One might be the guard and the other the handrail.
Thu, Nov 4, 2010 at 3:48:35 PM | Horizontal railing spacing problem
CDWdavid
5 Stars: 5 Votes
Please see attached 3D.
Problem about the railing slope
Fri, Jun 25, 2010 at 1:33:49 AM
Wire balustrade railing. The fancy ones
Wed, Apr 13, 2011 at 4:04:51 AM
railing miter at stairs
Mon, Jul 14, 2014 at 1:50:37 PM
How to pin irregular (custom spaced) horizontal curtain wall grid
Wed, May 26, 2010 at 1:19:17 PM
one proeperty of the railing
Wed, Nov 28, 2012 at 4:57:58 PM
Page generation time: 1.0747
