Forums >> Revit Building >> Technical Support >> Render Internal Lighting Issue
Thu, Nov 4, 2010 at 12:11:14 PM | Render Internal Lighting Issue
matatmicad
Yo,
Please could somebody provide a solution to our lighting issue, We are using 2011 Revit Architecture and we are trying to produce internal lighting renders but are receiving black "voids" at approximately where our roof level. The roof space is an open void with drop down pendants. It is almost as if there is a surface preventing us from viewing into the void, however, on an internal sun only render, we see the roof void clearly.
Sun, Nov 7, 2010 at 8:04:47 PM | Render Internal Lighting Issue
rkitect
rkitect Avatar
4 Stars: 29 Votes
I have seen this before and it still baffles me.  I believe it actually has something to do with the lights you are using.  Try placing a few studio lights (the ones with no geometry above the other lights and see if anything happens.  If nothing, try using a different light for the pendants.
Just verifying, you are not getting a "material missing" message in your render dialog, correct?
Lighting Render Issues
Mon, May 12, 2014 at 11:55:43 PM
Lighting Fixture Render
Fri, Apr 28, 2017 at 5:59:54 PM
External Lighting Night Scene
Mon, Oct 26, 2009 at 2:09:22 AM
2011 Lighting issue
Tue, Feb 15, 2011 at 2:27:18 PM
Render Issue
Mon, Aug 24, 2015 at 7:01:38 AM
Page generation time: 1.4745
