Forums >> Revit Structure >> Technical Support >> rotate entire structure off horizontal
Thu, Nov 4, 2010 at 10:33:44 AM | rotate entire structure off horizontal
inventomatic
We've created a 10'x10'x100' truss / bridge structure based on grids and levels. This structure will house a conveyor that is at an 8 degree slope. We've also modeled the two structures (towers) to support this truss. How do we place this truss on the two towers (of different heights) to get the truss to be at the slope it needs to be? Family? Group? What's the proper way of doing this? Surely we don't have to model the truss at the slope to begin with... if so, whats the best method for doing it this way? Any Ideas?
Sun, Nov 7, 2010 at 8:10:40 PM | rotate entire structure off horizontal
rkitect
rkitect Avatar
4 Stars: 29 Votes
if you have the datum at the top and bottom points of the slope, then you can create levels at the top and bottom points and use those levels to define top and bottom levels for the truss object.
If you model the truss object as a structural beam/truss/complex object from the templates you will be able to use those top/bottom definitions to create the slope.
HTH!
Horizontal Tubular Structure with floor
Wed, Aug 16, 2017 at 2:19:20 PM
rotate the entire model
Mon, Feb 21, 2011 at 9:18:55 AM
14
Need to Rotate entire building model
Wed, Jan 29, 2020 at 9:26:32 AM
Materials
Thu, Dec 8, 2005 at 11:21:18 AM
Wood frame structure Family
Sun, Feb 20, 2005 at 7:00:17 PM
Page generation time: 1.2271
