31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> calculated value not working
13 Posts No Rating |
I've got my areas for my occupant load plan, and a schedule - but I cannot get the "calculated value" thing to work so that it works like and XL spreadsheet. I want to divide "square feet" by a factor, and get a number of people. I get error messages about inconsistent units, and incorrect boolean operations. I've looked at the other threads I could find, but have not found anything that says what my likely mistake is. I've tried putting "Area/Factor" into the formula box, but that is not working. On some of threads I looked at for help I can not download the image attached to the post - just getting a little yellow smile face but no download. I'm using Revit 2011.
Please read your HELP on units and formula. Another thing you should always try is a search of the forums. In this case using the term "inconsistent units" would find this post from Mr Spot: "....Okay the confusion comes because cost is a number and area is m�. Therefore when you create a calculated value for total cost you select number... Now revit is looking for a number yet your units when for instance going cost*area is m�.... Try this cost*(Area/1) This will effectively remove the units from the value...." That answer should point you in the right direction to solve your problem.
Thanks - that worked.
Calculated Values |
Mon, Mar 3, 2008 at 11:01:17 AM
Calculated Values in Room Tags |
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated value |
Fri, Aug 6, 2010 at 2:17:19 PM
Calculated Value |
Mon, Dec 13, 2010 at 4:46:58 PM
Calculated Values |
Mon, Mar 20, 2006 at 12:58:54 AM
