Forums >> Revit Building >> Technical Support >> PDF Raster image as a super imposed backgroud
Wed, Nov 3, 2010 at 4:58:24 PM | PDF Raster image as a super imposed backgroud
Willbemore
I receive pdf raster civil images.  I would like to use the image as a super imposed back groud for the adjacent site.  How do you get the image to a scale.  Back in the day when i used autocad I would find a dimension in the image and scale it accordingly.  Also i am wiping out the back backgroud in photoshop and saving as a TIF (raster image).  Is there a way to get this to vector image so all of the lines  can be picked and the image removed for file size?
Sun, Nov 7, 2010 at 8:46:58 PM | PDF Raster image as a super imposed backgroud
rkitect
rkitect Avatar
4 Stars: 29 Votes
Once you place the image, you can use the scale tool to resize the image the way you would in autocad.  You will need to know a dimension and use it as a reference for the scale.
Unfortunately you will not be able to pick lines in vector images, in fact I'm not even sure you'll be able to import vector images although I have not tried.  However, just saving a file as TIF in vector format doesn't make the lines vector unless you plan on running it through a converter.
HTH
Raster Image display
Fri, Oct 10, 2008 at 6:08:26 AM
Raster Image
Fri, Jul 31, 2009 at 8:24:24 AM
Raster Image Draw Order
Wed, Feb 18, 2009 at 1:16:00 PM
raster image will not plot
Thu, Sep 24, 2009 at 8:43:42 AM
Perspective view image printing to PDF problem
Wed, Dec 3, 2014 at 8:03:55 AM
Page generation time: 2.3469
