13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> Inclined beam not cutting in plan view
Hi there I have drawn a beam system that is inclined (they are the rafters to the roof of my building). On plan view i can't get them to cut at the cut plain of the plan. they either show the entire length (even way over my cut line) or if the cut line in too low they do not show up in the plan atall. I also have a few mebers (the hips of the roof) that i drew as inclined columns. these do behave correctly with the cut plane. Wondering if anyone else has had this problem? any suggestions of solutions? If I could identify something Can i change someting in the fraiming family so that it works with cut planes the same as columns do? thanks for your help
Read your HELP searching for "CUTTABLE" - this will explain your problem.
Thanks for the reply... The beam I have drawn is a 'structural beam' so should be 'cutable'. Am i right in thinking that a beam will only show as cut on a plan when in 'fine' or 'medium' graphical style?
concrete beam on top of inclined wall |
Wed, Jun 20, 2007 at 11:09:17 AM
Beam not showing in Plan View no matter what I try |
Thu, Nov 5, 2015 at 4:29:31 AM
Controlling Beam Lines in plan view |
Thu, Sep 25, 2014 at 10:48:47 AM
Structural Beam Invisible Partial In Plan View |
Tue, Mar 20, 2018 at 4:39:48 AM
beam and wall connection |
Mon, Nov 23, 2009 at 12:24:04 PM
