Forums >> Revit Building >> Technical Support >> Civil 3d surface to revit topo surface
Tue, Nov 2, 2010 at 2:37:59 PM | Civil 3d surface to revit topo surface
petersonm
Hello everyone, I am trying to export a surface from civil 3d into revit. I am export a dwg showing all of the triangulation from civil 3d and importing it into revit. The surface looks correct when i import it, the problem comes when i create a toposurface. When i create a toposurface it "simplifies" the surface, all of the detail pretty much gets smoothed out. i.e. curbs just go away.. it seems like revit is not creating breaklines and removing point as it feels. So I guess my question is how do i get a surface into revit without doing this? Is their a breakline tool in revit? can i import a breakline file into revit? I know revit is not a site program by any means, but it seems like i should at least be able to import a surface accurately. I also tried setting my contour interval to .1' in civil and tried importing it like that, it creates a better surface, but it is still far from good.
I attached a couple pictures of the surface in revit and terramodel, hopefully everyone sees what im getting at.
Any help is appreciated.
thanks.
Fri, Feb 11, 2011 at 8:30:44 AM | Civil 3d surface to revit topo surface
palladio1234
5 Stars: 3 Votes
bump
Fri, Feb 11, 2011 at 9:25:22 AM | Civil 3d surface to revit topo surface
petersonm
hey fyi autodesk has a add-in called roads and terrain that can import corridors from civil 3d. it is pretty limited, but it can get the job done if what your working on is somewhat simple. Also if you ever want to go from civil 3d to 3ds max design, they have another add-in called dynamite VSP. I have a fair amount of experience going between those 3 programs now, so if you have any questions ask away.
Wed, May 11, 2011 at 7:36:44 PM | Civil 3d surface to revit topo surface
Eggs
Hi Peter
From what I know revit doesn't have the ability to create breaklines, this should be done in C3D as you have done.  I wouldn't import the contours into revit as it will change the surface, as in the instance with Kerb and Channels it could flatten this out. I would only use the triangle file, this is a true indication of the surface.  If it is deleting points from your surface, that sounds like its creating a "Simple surface"
Hope this helps.
Dan
Wed, May 11, 2011 at 11:00:38 PM | Civil 3d surface to revit topo surface
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could try Eagle points LandCADD Siteworks as it may achieve a better result.  The other option would be to import in parts of the topography separately.  Revit doesn't handle reatining walls or vertical surfaces on topography very well.  So by doing it in parts you will avoid some of this simplification Revit is doing.
HTH.
Regards,
Chris.
Wed, Oct 12, 2011 at 5:13:49 PM | Civil 3d surface to revit topo surface
CRB14
Hi Peter,
Just seen your post re; experience going between 3D programs. I have been sent a dwg file by surveyors and am now required by the client to import it into Revit, cut a road into the surface. Iive been trying to figure out how I can manipulate the surface in Revit, by making it a topographical surface. At the moment it's imported as one 'mass' and I'm not having much luck with the manipulation. I wondered if you might be able to shed some light?
Thank you
Charlotte
Thu, Oct 13, 2011 at 7:14:34 AM | Civil 3d surface to revit topo surface
Follow your HELP on creating a topo surface from a CAD import.  Then you have two possibilities.  Use graded regions or edit the surface adding additional points or modifying the ones there.
NOT A MASS!!!!
CREATING A TOPO FROM A CIVIL CAD FILE
Fri, Sep 29, 2017 at 3:22:33 PM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
placing a street, vegetation and barrier or railing on topo surface
Tue, Jan 17, 2017 at 5:47:40 AM
Page generation time: 4.4554
