Forums >> Revit Building >> Technical Support >> Any trick to lock the a curtain wall?
Mon, Nov 1, 2010 at 4:25:48 PM | Any trick to lock the a curtain wall?
xixiha
This curtain wall(in Revit term) make adjusting the curtain wall(in design term) very easily and fast. But the headache is once you get the configuration of the curtain wall you want, you can't lock it. It's easily affected by the change of its context or changed accidently by other team members. Is there any way to lock it once it's done?
Mon, Nov 1, 2010 at 4:36:42 PM | Any trick to lock the a curtain wall?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Use the command PN, pin, select all and pin them.
Mon, Nov 1, 2010 at 4:39:33 PM | Any trick to lock the a curtain wall?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Select all your CW system and GROUP them!
 "If you tell the truth, you don't have to remember anything"
Tue, Nov 2, 2010 at 8:30:13 AM | Any trick to lock the a curtain wall?
I would NOT group your curtainwall.  In the AutoDESK model performace guide, they suggest yous "Avoid maintaining unnecessary groups. Delete unused groups from the project browser."
My question is why the need to lock at all?  You should not need to do very much of that.  Could it be that you are using curtainwall types that have pre-set spacings and the curtainwall is reverting to that condition?  This is a common problem with new users.
Pre-set (automatic) curtainwalls are great for initial layouts because all the spacings, mullions, panels can be set ahead of time but when you modify these, you have to unlock any areas you want to change. If you don't do this properly, you can make changes that look correct but the next timeyou open the project, everything moves to its original location.
We actually prefer to layout using the automatic, then switch the entire CW to a completely manual CW but keeping all the automatic layout.  Then we can modify all elements.
Curtain Wall Panels!
Wed, Oct 8, 2008 at 7:16:05 AM
CURTAIN PANEL TRICK -- HELP!
Fri, Nov 30, 2012 at 2:05:27 PM
Curtain Wall - Break level association?
Thu, Jul 10, 2008 at 4:36:12 PM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
wall closure wrapping at doors, curtain walls
Fri, Apr 15, 2011 at 10:50:26 AM
Page generation time: 0.5971
