Forums >> Revit Systems >> Technical Support >> No temporary dimensions on component
Mon, Nov 1, 2010 at 10:46:51 AM | No temporary dimensions on component
shjenkins
I placed a face-hosted boiler in my existing plan (face-hosted to the floor).  I want to have it a certain distance from two walls but there are no temporary dimesions that show up to allow me to do that.  Any suggestions?
Mon, Nov 1, 2010 at 3:50:57 PM | No temporary dimensions on component
cbieser
1 Stars: 1 Votes
You can always place a dimension between the two points you want, select the object, edit the dimension, and delete the dimension when finished.  Maybe not the best solution but it works.
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Wed, Jul 1, 2009 at 10:50:50 AM
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:20 PM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
temporary dimensions require me to pan to see them
Sat, Mar 26, 2016 at 9:52:41 AM
Page generation time: 0.1771
