22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> painted split face doesn't show in dependent view
77 Posts No Rating |
We splitted the floor surface and painted in certain region in the parent view, but the painted region doesn't show in the dependent view. is that normal?
No, a true paint is model based. Are you sure you split face and painted? Maybe someone used a filled region instead. If this is truely a split face paint, then you have found a bug and should report it. You might try duplicating the origional, creating a dependent and seeing what happens.
I am sure the surface is splitted first and then paint. I created the dependent view before I did the surface painting, I don't know if it's why. I created another dependent view just now (now it's after the surface spitting and painting), and the new dependent view show the painted surface.
split face not remembering material - RAC 2008 |
Thu, Nov 20, 2008 at 3:13:31 PM
Dependent view doesn't crop call out area |
Fri, Aug 19, 2011 at 2:24:48 AM
Can't split certain faces |
Thu, Dec 6, 2012 at 6:59:31 AM
Glass transparency in elevation view & split face command |
Sat, Mar 22, 2008 at 12:01:35 AM
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
