27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> Titleblocks
3 Posts No Rating |
Looking to be able to have editable text parameter in a titleblock that is a sub catagory to the sheet title. So each sheet can be different than the next but editable in the browser. thanks
If you mean you want something that will allow you to call two sheets "Same Name" because you have a second field of dat, you will not be able to do that. You can have a sheet "One name" and another sheet "different name" and have another parameter assigned to sheets that can be edited from the browser but it will not be part of the sheet name. You can also assign a parameter to a sheet that can be part of your browser organization and you could use it in browser sorting.
TitleBlocks |
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options |
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks? |
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks |
Mon, Mar 17, 2008 at 3:03:10 PM
Multiline text on Titleblocks |
Sun, Oct 5, 2008 at 8:17:13 PM
