25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Level Visibility in different Views
2 Posts No Rating |
I have a sheet setup with two elevations and one section on it. In the section, I need to callout a set of levels (storefront opening, soffit level, etc) without having them show up on the two elevations. Is there anyway to add a level marker to one particular drawing without it appearing on other drawings on the same sheet? Also, is there any way to customize the shape of the crop region for a drawing? I need to hide a corner of an elevation, and a rectangle is not doing the trick. thanks.
Part one - Read this in your HELP: Example of Datum Visibility in Project Views In addittion, you can aklways "hide in view" any element. Part two: No way to cutom the crop region. You can hide the ccall-out bubble and use linework then in the view, use masking regions.
2 Posts No Rating |
'hide in view' works temporarily, but when I plot the sheet everything is visible. regardless, thank you for your time
Hide in view is not temporary !!!! The eyeglass is temporary hide in view. To Hide in view, right click on the object and pick hide in view.
Visibility/Graphic Overrides for all views at once |
Fri, Jul 29, 2011 at 8:22:36 AM
Visibility Problem - please help!!! |
Fri, Jan 11, 2008 at 10:20:02 AM
Design Options - Efficiently Changing Option Visibility in Multiple Views |
Wed, Nov 29, 2006 at 11:26:41 AM
Hide Visibility in all views? |
Thu, Jan 19, 2012 at 1:58:32 PM
Sections, different level/views |
Sat, Aug 5, 2017 at 7:34:44 AM
