15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Design Options in linked files - possible to set 'permanently'?
I have a site plan with 10no linked models of a bungalow, the bungalow has 3no design options and I want to set the design options for each instance on a permanent basis i.e: I do not want to have to set the design option for each instance on a view by view basis - is this possible or do I have to set it in each view? Working in '09 Cheers!
check the VG (it appears at last as a tab "design options" of each type of view, then create a template vg, from there copy the vg to the rest of the views.
Thanks, that's BRILLIANT! I never thought to use the VG settings that way - All I did was create a template called 'RVT Links Settings', un-checked all the boxes that control all the other settings & kept it to the RVT links only & can now apply it throughout - thanks a bunch NC
Permanently unchecking the 'Editable Only' box |
Mon, Oct 27, 2008 at 11:39:20 PM
Design options issues |
Thu, Mar 2, 2006 at 10:35:31 AM
Design Options in Linked files |
Thu, Nov 17, 2011 at 5:38:23 PM
Linked Files and Design Options |
Thu, Jun 4, 2009 at 4:33:11 PM
Design Options issue |
Thu, Jun 16, 2005 at 9:00:05 AM
