Forums >> Revit Building >> Technical Support >> RMEP2011: Need to add Field to Air Diffuser Schedule
Thu, Oct 28, 2010 at 11:54:05 PM | RMEP2011: Need to add Field to Air Diffuser Schedule
bxuser
Hello
I need to add "Mounting" to my Air Diffuser Schedule as a field. It's not part
of the "Available fields" so, don't I "add" the parameter? When I "add Parameter" as a
name, Disicipline is common, type is text, and group is mechanical. When I say ok
and go to my model to update "mounting" in my properties dialog box under the group
mechanical the schedule does not update when I type in say, T-BAR. "T-BAR" does not show up in the schedule.
I want my schedule to show "Mounting" as a field and "T-BAR" as the data entry.
HELP
Linear Air Diffuser
Sat, Jun 11, 2016 at 12:58:53 AM
Revit Revisions - Add field
Tue, Jan 15, 2013 at 8:23:50 AM
11
REVIT MEP, Diffuser Airlfow Parameter isssue
Mon, Jun 21, 2010 at 1:46:22 PM
HELP with air terminals
Tue, Oct 25, 2011 at 9:44:46 AM
13
ADDING A FIELD TO REVISION SCHEDULES
Tue, Feb 24, 2009 at 11:19:41 AM
Page generation time: 0.4063
