Forums >> Revit Building >> Technical Support >> Floor with Valleys and Ridges - Hosted Components Won't Slope
Thu, Oct 28, 2010 at 1:28:38 PM | Floor with Valleys and Ridges - Hosted Components Won't Slope
mchristoff
I have a parking garage floor that I've used valleys and ridges to provide the slope to the drains of the floor (about 6" of slope between low and high points. I can't get floor hosted elements (currently only working with 2d ones) to show up correctly in plan because they are disappearing into the sloped floor. Is there any way to get them to follow the slope?
 I've found with non-floor hosted 2-d components you can just set the elevation above the 6" and it looks just fine in plan, but with floor hosted components (for instance a janitor mop sink or a dock leverler), you can't do that.
Any  suggestions for how to get them to display correctly?
 Thanks so much!
-Mike
Thu, Oct 28, 2010 at 1:55:52 PM | Floor with Valleys and Ridges - Hosted Components Won't Slope
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Just a thought ... did you set your 2d elements in course, medium, or fine views when you created them? try to set your view to the correct ones.
 "If you tell the truth, you don't have to remember anything"
Thu, Oct 28, 2010 at 2:00:59 PM | Floor with Valleys and Ridges - Hosted Components Won't Slope
wheelergc
Have you tried making the component into a face based family instead of floor based?  I am not exactely sure how to do that seems like that might be the fix.  I usually leave a flat spot at the bottom of the valley and that is where I place my floor based trench drains and the like.
I don't want to be interesting. I want to be good.
Thu, Oct 28, 2010 at 2:01:36 PM | Floor with Valleys and Ridges - Hosted Components Won't Slope
gdoherty0102
3 Stars: 2 Votes
I think there are two possiblities, each of which could give you this issue.  First most of the time families that are level based have a parameter checked in the family "Always Verticle" so this will cause this.  If fixing this still does not help you may have to switch from a floor/level based family to a face base family.
HTH
Slab editing - simple slope with more than 4 corners [ 1 2 ]
Wed, May 6, 2009 at 5:33:54 PM
17
railing on slope won't go to exactly 3'-0" from the floor
Thu, May 14, 2020 at 6:23:18 AM
Floor hosted family to not be hosted by floor
Tue, Dec 23, 2008 at 6:47:16 PM
Ceiling hosted components
Sun, May 9, 2010 at 12:02:14 AM
Wall hosted components in groups............ [ 1 2 ]
Fri, Nov 3, 2006 at 8:09:00 AM
15
Page generation time: 1.2190
