Forums >> Revit Building >> Technical Support >> PAT file scale issues
Mon, Oct 24, 2005 at 5:43:15 PM | PAT file scale issues
arccodex1
3 Stars: 1 Votes
Maybe someone can take a look at this PAT file and tell me why it won't scale to larger than 2.22 in Revit. I have simpler patterns of the same size that will scale fine. Post edited on 2005-10-24 17:45:56
Mon, Oct 24, 2005 at 6:04:22 PM | RE: PAT file scale issues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can scale it larger than this it just won't preview. This is because the actual preview will show a tiled version of the pattern, if the individual tile is larger than the preview box then is won't show. HTH.
Mon, Oct 24, 2005 at 6:22:57 PM | RE: PAT file scale issues
arccodex1
3 Stars: 1 Votes
True, it won't preview, but I also get an error message "Pattern too big" when I try to hit OK. Post edited on 2005-10-24 18:23:16
Mon, Oct 24, 2005 at 6:29:51 PM | RE: PAT file scale issues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
So it does... i was in an active project so i didn't actually press okay... I really don't know... Best to consult Autodesk on this one...
Thu, Mar 20, 2008 at 7:03:28 AM | PAT file scale issues
ppinc
I had/have had the same problem and have not yet resolved it fully, but I beleive I am going in the right direction, perhaps you might be able to expand on it as I am still experimenting. What I have realised is that the scale of the pattern is relative to the scale in the package it was created in....i have had to open  a number of hatch .pat files created in AutoCad and have re-scaled them-sometimes smaller or larger depending on what is r'qd and then re-imported them....play around with this it might sort out your problem...ie the scale to autocad is inversely proportional to revit???
Need help with a PAT file
Thu, Sep 29, 2011 at 12:55:36 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:31 PM
I know how to scale patterns but to what
Wed, Jul 18, 2007 at 7:03:08 PM
.pat file
Mon, Aug 26, 2013 at 2:56:05 AM
Page generation time: 0.8036
