Forums >> Revit Building >> Technical Support >> Cant Delete one of My worksets...please help
Thu, Oct 28, 2010 at 8:26:57 AM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I've have created a series of worksets and in the interest of consoldating our model for our project team, I have gone back to delete un-neccsary worksets. I have successfully moved all model elements into the worksets that I want them in but there is one workset that stubbornly refuses to give me the option to delete. All of the other worksets have this option. The workset is completely empty as far as I can tell, but I'm at a loss. How I can I get this workset deleted? Thanks
Thu, Oct 28, 2010 at 8:33:02 AM | Cant Delete one of My worksets...please help
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Does anybody have it checked out?
Is it set to Current?
Are there any warnings or messages that pop up when you try to delete it?
Thu, Oct 28, 2010 at 1:17:21 PM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
It wasn't set to current and there were no warnings. I've tried it both ways.The option to delete is simply grayed out. I wish there was a purge command to make sure that everything is deleted off of the set.
Thu, Oct 28, 2010 at 1:18:10 PM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Also, no one has it checked out or borrowing it.
Thu, Oct 28, 2010 at 1:30:48 PM | Cant Delete one of My worksets...please help
lunchtrayrider
3.5 Stars: 7 Votes
which workset is it?
Thu, Oct 28, 2010 at 1:33:26 PM | Cant Delete one of My worksets...please help
The initial worksets are all system level and can not be deleted.  Workset1 - Shared Levels and Grids
Thu, Oct 28, 2010 at 2:13:01 PM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Its not shared levels and grids. Its one that I created and now cannot destroy. Still not sure what to do because Revit was considerate enough to make this process irreversible.
Thu, Oct 28, 2010 at 2:22:06 PM | Cant Delete one of My worksets...please help
lunchtrayrider
3.5 Stars: 7 Votes
i've deleted shared levels and grids before.  oops.
 it isn't the last workset is it?  you should also try checking it out and then deleting it. if you haven't already.
Thu, Oct 28, 2010 at 2:29:51 PM | Cant Delete one of My worksets...please help
From the HELP: NoteYou cannot delete the Workset1, Project Standards, Families, or View worksets.
NoteYou must be the owner of the workset to rename it.
If you renamed workset1 (if you can rename it) - it is still.... workset1
Thu, Oct 28, 2010 at 3:20:31 PM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I guess I will try to rename the undeletable workset to one of my other worksets and delete it in return. It looks like there's no way around it. Thanks anyway everyone I appreciate the responses!
Thu, Oct 28, 2010 at 3:22:53 PM | Cant Delete one of My worksets...please help
lunchtrayrider
3.5 Stars: 7 Votes
Yea, I think WWhub has the same idea i was pondering if someone renamed Workset1 because you can definetly not delete Workset1
Thu, Dec 2, 2010 at 5:02:57 PM | Cant Delete one of My worksets...please help
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
You're exactly right. That ended up being the issue and followed everyones advice to solve the problem. Thanks so much and sorry for the late reply.
Mon, Mar 5, 2018 at 12:43:27 AM | Cant Delete one of My worksets...please help
#13
loganlkemp
Very old thread, but if anyone still has this issue:
  • For the workset you want to delete, select "Editable". The "Delete" button will become available.
  • Close the workset dialouge.
  • Re-open the dialouge and delete the workset.
Doesn't work with default worksets.
Thu, Feb 14, 2019 at 1:48:12 PM | Thanks, loganlkemp!
#14
landholt
I was having this issue with worksets I definitely created, and your tip worked. Thanks!
Quoting loganlkemp from 2018-03-05 00:43:27
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:40 AM
Cant delete view
Wed, Apr 23, 2008 at 3:43:55 PM
Tue, Oct 23, 2007 at 2:36:13 PM
Page generation time: 2.4398
